Unread 12-29-20, 12:29 PM
Originally Posted by Snake View Post
Not a maintainer, a breaker. Experienced this a number of times, mostly in colder climates. High heat not to often. Various Mechs have bleed/drained then did refills with repeated manual crankdown of gear. (Guess whom did the cranking?) Never had the problem on M337s only G&H models.
Thank you, Snake. We’ve done the drain/bleed approach and the air keeps coming back. We’ll keep plugging away trying to find something that works...
Rick
N337K-FT337GP
KLOU
