Broken Entry Step
GAdams. Had the same problem. Removed the step took it to a certified local (Non-aviation) welder. He ground around the break, TIG or MIG welded the break THEN HE FITTED/WELDED A DOUBLER AROUND THE WHOLE BREAK. I re-attached the step with heavier rivets and it's works/looks fine!
