Unread 12-24-20, 08:46 PM
hayesjaj hayesjaj is offline
Belt, suspenders and ladder? 3 artificial horizons? I'd go with just two (your choice for backup - elec or vacuum) and use a stratus/ipad as your 3rd if you REALLY want a 3rd.
So, here's my thoughts:
Primary will be the Aspen E5. Mostly, this is for the HSI, but eventually I will probably upgrade the whole thing to a MAX.
The AV20 is much more than an AI (although that could be very helpful). It does a bunch of air/data computations and gives density alt, TAS, and it will give me AOA and G loading. All for $900. Easy pick.
Last one is the original from Cessna. It needs to be retained until I dump the 400A autopilot, which will happen when A) mine breaks so badly it isn't worth repairing or B) one of Dynon Garmin or STEC decides to make available a digital AP.
