Thank you for the reply. Everything is wired correctly according to the wiring diagram in the maintenance manual, however when operation in the aircraft the close switch and to be moved to open position and the open switch moved to the closed position. I also had to add .090 shims so the switches would close correctly. All works fine now, so either the wiring diagram is labeled incorrectly or the wiring under the panel is wrong. Either way system works as advertised now.
Thank you
Dan
P337-0168
