Unread 11-18-20, 12:22 PM
B2C2 B2C2 is offline
I have a 1969 T337D, non pressurized and no pressurized mags. I have tempest fine wire plugs and GAMI injectors. I have also replaced all the ignition wiring and rebuilt the magnetos. The airplane flys nicely LOP with this setup. I occasionally have experienced bumps when operating at altitude above about 17K LOP. The highest I have flown it is 21K and it was the same experience, occasional ignition bumps, but not rough operation. I have found going to ROP stops this. You don't mention if you are running LOP or ROP but you might want to see how this effects the performance.
