Unread 10-28-20, 04:30 PM
Frank Benvin's Avatar
There's one on Ebay for about $2200 IIRC.
EDIT: Here it is, make an offer: https://ebay.us/uu9I5R
That prop is for a 66 It can not be used on a 73 check AC6E
XIII - Model 337G, 4-6 PCLM (Normal Category), Approved December 18, 1972
Engines (Both) Continental IO-360-G or -GB
*Fuel 100/130 minimum grade aviation gasoline
See NOTE 5
*Engine Limits For all operations, 2800 r.p.m. (210 b. hp.)
Propeller and 1. McCauley constant speed full-feathering propeller installations
Propeller Limits (a) S/N 33701463 through 33701748:
(Front) McCauley D2AF34C306/78CAA-0
Diameter: not over 78.0 in., not under 76.5 in.
No further reduction permitted
Pitch settings at 30 in. sta.:
low 11.0°, feathered 82.0°
(b) S/N P33701449, 33701749 and up:
(Front) McCauley D2AF34C310/90DEA-12
low 9.9°, feathered 82.0°
(c) (Rear) McCauley D2AF34C307/L78CBA-2
Diameter: not over 76.0 in., not under 74.5 in.
low 11.0°, feathered 80.0°
(d) (Front) McCauley hydraulic governor CF310D1/T1 or CF310D2/T1
1967 337B
