Yes, I’ve put CiES senders and a JPI960 in my plane. The installation required a little debugging (it turns out that the senders should not be grounded to the airframe - I think that was the problem), but once that was solved they are quite nice. Another Skymaster in the area also upgraded but used three sensors per tank instead of the two per tank that I’ve got and as a result I think they have more accuracy in the middle of the range.
