Unread 09-07-20, 02:19 AM
Sounds like you might have a problem with the flap/trim system. It can break or not be rigged correctly. A quick test (on the ground) is put full flaps down, then trim nose all the way up. Then retract flaps to zero; the trim wheel should start spinning on its own. If it doesn’t then it’s probably broken.
