Unread 08-11-20, 09:45 AM
My courtesy light in the overhead clamshell door is also inop (someone cut the wires where the door meets the fuselage). I'll try your bulb suggestion, if I can figure out how to get voltage to the wiring harness.
Don't forget, there is a 1A glass fuse under the front cowl on the pilot's side that feeds the courtesy light circuit. Mine was blown, I bet yours is too.
