Unread 07-30-20, 06:33 PM
If you keep the plane it's probably a wise choice to go with the more common size. Any certification issue with changing to that size? What model did you buy? I thought you bought a G model correct? Not sure they can go to the other size tire without a field approval. Which shouldn't be hard to convince with all the older Skymasters rolling on them
