Unread 04-21-20, 01:26 PM
7 quarts seems to be about max from what I have heard. Typically you would allow it to stabilize and see where it levels off at. My engines like 6 quarts. If I keep the level at 7 it greases things up more. Also depending on how hard you run the engines seems to change the amount blown out. If I run 2500 rpm it will tend to be more grease if I run 2350 rpm it seems to be less.
Also not all dip sticks are stamped correctly. This is retaliative to knowing exactly what you have in the sump but not necessarily where the level stabilizes at. But when you change your oil dump 6 quarts in and let it sit for a little bit then see what the stick says. Remember the filter takes a quart too. When my dip stick says 6 I have dumped 7 quarts in the engine.
