Thread: Oil in Belly
Unread 03-12-20, 12:00 AM
as per Rambo
making a list, 4 fluids in the airplane: gas, oil, hydraulic, brake (also hydraulic)
it's not gas collecting
oil level not dropping and if you did Dr Dave test, that's out
brakes not great: possible
hydraulic needs topping off (must be going somewhere) and gear door dropping-suspicious
I had a very small leak from my emergency hand pump. By the time the hydraulic fluid mixed with the dust and grit in the belly it was black, not red, dripping out the weep hole. Don't count on the color. I ended up using scope to confirm hand pump was the source of the leak. You can get from harbor freight and on occasion have seen at hardware store.
Chase what you know is wrong. Hydraulic fluid is going somewhere. Plus I would put a hydraulic leak pretty high on the list of something to investigate whether or not it's the problem in the end.
