Thread: Oil in Belly
Unread 03-11-20, 05:53 PM
GAdams GAdams is offline
Hot Grease
Oil level is not dropping. Hydraulic fluid level seems to need servicing occasionally. I can always tell because the left main gear door pops open. Put a little fluid in and its fine. That has stabilized. Hydraulic power pack was overhauled less than one year ago. The fluid doesn't look polluted with another fluid or dirty such as old oil. Brakes work no leaks, not the greatest stopping power. If you clean up the belly inside and remove the fluid from the bottom of the aircraft it returns on the next flight. Yellow, consistency like a thick oil and doesn't really have much of a smell.
