Hmmm. Going through the pump issue myself. "stole" one of quality's good pumps a few weeks ago. I haven't sent my core in yet. Wonder if it will be good. If it is, wonder if can direct it your way....
be aware. slight mixup slowed things down: rear pump is a little different than front pump in terms of drain port location where mounts to engine block. check "dash numbers" on the pumps. I have an E model with dual pumps.
if my core is bad, I already know it will be $2000 on top of the cost of the pump. so yes expensive.
