There is a small metal tube on the under side of the wing and the tail boom pylon for the respective fuel bowels. Buy a package of old fashion pipe cleaners and work your way down from the top and up from the bottom side to clear the debris. 100 PSI of air is too much. You could try a gentle stream of air. Use the same cleaners to open the holes on the bottom of the rudder fairings. Likely they are plugged too.
