  #30
Unread 05-13-19, 03:46 PM
DrDave DrDave is offline
Jeff:
You may want to consider a spacer between the panel and the mounting holes. This would look like a license plate frame. I'll send you pictures. I would also encourage you to line the panel area with thin pieces of polycarbonate. The biggest offenders in your picture is the tie bars. The tie bar you have pictured should be good for 400 amps. I made the same mistake with the 3TC-7's the first time as well.
