  #28
Unread 05-13-19, 03:16 PM
DrDave DrDave is offline
Jeff:
In looking closely at the new panel it appears that you have the taller 3TC breakers. Is there enough clearance on the back side for those? I love the picture of your old circuit panel, otherwise known as what could possibly go wrong here. Your new panel looks good. Are you doing a dedicated avionics bus? It is interesting to see the burned terminal connection in the bottom left of your old circuit panel. That was causing problems somewhere.
You are doing a really nice job on this project. This will be a great system once installed.
