  #23
Unread 04-01-19, 03:14 PM
DrDave DrDave is offline
Hi:
I'm running off an avionics master breaker to a switch and then back to feed the entire avionics bus. You could run to two switches for a backup avionics switch if you want. As I recall the starter mounting stud was larger than 5/16". I will measure tonight and report back.
