Unread 02-22-19, 05:21 PM
DrDave DrDave is offline
I'm skeptical of the quality of that crimper. If you save the $55 and measure and mark your wire you could send it to me and I'll crimp it for you. I'll even label it and shrink tube the terminals. I have the terminals too. I'm guessing it will be around 15' of wire.
I have no plans to put a relay in the circuit. There is no large load on the circuit. The only load even worth mentioning is during transmit. It's <5 amps. I will be using a Cuttler-Hammer switch. I can't remember the part number right now. I'll look it up.
