Unread 02-22-19, 12:20 AM
DrDave DrDave is offline
Hi:
There is going to be an avionics master switch on the panel. It will go from a breaker on the main bus to the switch and then back to power the shorter avionics bus on the lower row of the panel. There are two separate buses on the bottom row. There is an empty breaker next to the avionics bus that will feed the avionics master switch and bus. BTW, that narrow jumper will carry 105 amps.
I do not recall the size of the lugs on the starter. I will look tomorrow and let you know. Do you have the crimp tool for the larger size lugs? As I recall that was a $350 investment in that crimper.
