I have the OEM Cessna checklists as per the pic.
It is adequate, but thats about it. (Airplane has been reconfigured since it left the factory. New avionics, upgrades, etc etc etc.)
It IS NOT a direct copy of the checklist from the owners manual / POH.
Given when it was written, its a pretty good document.
I keep it in the airplane, but what I've gone to is the checklist system within Garmin Pilot on my iPad. (I have no doubt that ForeFlight has the same/similar feature.) It lists everything in red, and as you check the items off, it makes that item green. Great if you get a radio call or other distraction as you are running the checklist.
I started out with the factory checklist, then ran through it on my simulator a dozen times, adding things as required to make a more thorough checklist.
Seeing as I fly with my iPad mounted to the yoke, its always there, and I always use it.
Leighton.
