Unread 11-27-18, 10:29 AM
I have the earlier model front cowl baffles as shown on the first link you listed. I just wonder what the newer style would have changed. I know the design of the cowl inlet on the G models is different than early like mine so that is one reason there is a difference. The rear baffle that Don has for your G model cowl is definitely blocking a lot more air than the original early model. You are in some cold temps up there so it can't hurt to have these. You may still need to cover some oil cooler too but you will know when you try them.
