Unread 09-27-18, 10:47 PM
spurlockda spurlockda is offline
spurlockda is on a distinguished road
A different question on control cables
Speaking of control cables, I think I am having a problem with them of a different sort.
I believe that in some point in the past, maintenance performed for the owner(s) resulted in the cables being ??re-installed?? Unfortunately, it seems like they were not re-installed in the right locations. Possibly routed incorrectly but one has a huge bow where the cable exits from the tunnel in the aft wheel well and before it goes up through the shelf into the aft engine compartment. In addition, the aft prop and throttle levers have restricted travel at the end of their throws. One way I think I can tell they have been messed with is that they are interleaved in the hyd lines aft of the under-floor pressure bulkhead.
I haven’t been able to find anywhere that explains which control cable goes where between the levers and the engine.
Can anyone steer me in the right direction?
