The industry seems to be moving towards an accelerate stops distance computation by computing the takeoff ground roll with two engines plus the stopping distance, it doesn't matter two engines running or not. If you wish to be more conservative compute the two engine takeoff distance to 50' plus the landing distance from 50' and that becomes Balance Field Length. It assures you won't run off the runway in these older aircraft. No Guarantees! Wet runways add 50%. Snow add 100% and Ice covered runways don't go!
