Unread 10-20-02, 08:59 PM
I HAVE A 1968 337C. I DON'T KNOW IF THIS IS THE BOOK METHOD BUT FOR HOT STARTS I NORMALLY PULL MIXTURES TO IDLE CUT OFF, THROTTLES FULL FIREWALL, AND RUN HI BOOST PUMP FOR ABOUT 5 SECONDS. PUMPS OFF AND ENGAGE STARTER AS SOON AS IT FIRES BRING THE THROTTLE BACK AS YOU ADD MIXTURE. IT'S A LITTLE TRICKY WITH THE LEVERS BUT WORKS EVERY TIME.
