Unread 09-20-17, 09:18 PM
Keith
It deletes the main gear doors and the actuators that operate those doors. I requires that you remove the doors and actuators and then replace the doors with a composite panel that allows the gear access to retract without opening. That opening stays open at all times. Very much like the C210 later models.
http://www.rtaerospace.com/gear_door.htm
