Unread 09-09-17, 07:39 PM
Originally Posted by Kim Geyer View Post
There is a switch mounted on the bottom aft of the power pack. if you follow the linkage from the landing gear handle to the power pack is mounted on the outboard side of the power pack where the shaft goes through. it operates the doors to closed when the handle is in the neutral position. at least that where it is on our 337E
Kim
No Kim that wasn't the problem in this issue. I looked over the schematics and I think you are referring to the DOOR SOLENOID. I have never had any issues with this valve or switch.
