Unread 05-03-17, 07:21 AM
kragby kragby is offline
kragby is on a distinguished road
door trim
Appreciate the feedback but I'm assuming what was in there was some sort of nonstandard retrofit and have not located anything that would work. I found a satisfactory substitute however and may work well for someone else. The foam insulation for hot water pipes - carefully cutting a strip on the adhesive side around 1/2 inch wide worked quite well. The angle and slight curve of the adhesive side fit well and solved the problem.
