Sk
Kim,
I'm slightly embarrassed to say that until yesterday when I posted this, I had not even heard of service kits. Specifically because I am interested in this one, but in general, can you give us all a primer on where to find the list of SK for the 337, and how you tell which ones can be applies to which models (or serial numbers)?
On this particular one, it sounds (based on your post, plus what I saw in MM) that you replace the rate of change controller with a valve....sounds like it would save time at overhaul (ie one less controller to overhaul). plus I'm guessing they had other reasons for the retrofit that might be beneficial. So I am interested in digging into it further.
Robert
