Unread 10-20-16, 09:01 PM
Under/Over Voltage Sensor
My model 1968 C Skymaster has a Under/Over Voltage Sensor that is located behind the throttle quadrant. This unit is suppose to sense High Volts and Batt Discharge situations and then lights up a light above the Master Switch. Mine hasn't worked for a long time and I was trying to get it back on line. I have two other units that are "as removed" from Skymasters but can not get either of those to work either.
Has anyone had any experience with this unit? There is a board with resistors and transistors also a capacitor. I tried my board with another capacitor and nope.
See the attachments for info
Name:	Screenshot 2016-10-20 20.49.08.png
ID:	1684   Click image for larger version
Name:	Screenshot 2016-10-20 20.45.11.png
