Gear Won't Retract
I Have a 1974 337G, three flight ago when I pulled the gear lever up after take off, the gear wouldn't retract. The doors would open, you can hear the power pack working bu no retraction of the gear. Had the mechanic check it and put it on the jacks and according to hin the problem was miss alignment of the from gear. Flew it afterwards, died three landings and worked OK. Then last sat. flew it again and the same problem happened again. Now the doors open, the power pack works but the from gear don't move either.
Any suggestions on what to check or any input on someone the has had a similar problem will greatly be appreciated.
Regards,
Rod
