Unread 08-07-16, 01:39 PM
bigcheese
Starter sw replace
I'm being very lazy. It's 90 deg F and I am at home, not the airport.
MY rear starter switch sometimes doesn't shut the engine. A tap with an awl should tighten the rivet on the back of the switch and be done with it.
BUT, ....does anyone know if the electroluminescent panel needs to come off to access the nut holding the starter switch, and to replace the starter switch, or is the switch just held in by its nut accessible on TOP of the panel?
Two mins getting the knob off would answer, but its 30 mins away.
