1965 Cessna Skymaster Specs
600/900 SMOH
300/600 STOH.
5500TT
All new EI Engine Instruments with alarms
New JPI EDM 790
New Spin on oil filter conversions
New bracket air filters
New front engine mounts
New main tires
Rebuilt front nose strut
New leather interior-6 place
All new front and rear engine/prop/mixture control cables
Radio Rax Avionics Rail System
New aluminum baffling rear engine
New rear muffler
New exhaust gaskets and studs
All front and rear exhaust reconditioned with high temp stainless hardware
New vacuum pump filters
Rebuilt rear starter
Wig Wags
Electric elevator trim
All new Scat tubing
New Skybolt stainless cowl fasteners
New stainless steel external fastener kit
All cowlings cleaned and interior surfaces painted with zinc
Garmin 300XL
KX175 Nav/com
King transponder
King audio panel
PS engineering intercom
O2 door-military style paint
Strike finder
Tanks inspected and serviced
Digital fuel gauges
Aux tanks-120 gallons total
Custom avionics panels
I have replaced all hardware with new whenever it was removed, all grommets replaced. The lord mounts on the front mufflers and front cowl flaps are new. Much of the wiring has been replaced
New front and rear voltage regulators
+ spare parts, original front door, extra parts from another 337.
My wife was diagnosed with Lupis last week after a year of ongoing health problems. I was building this 337 to take the family on trips but this diagnosis will mean my time will be spent with my wife and little ones at home. I am just looking for something to poke holes in the sky.
I know I have way too much money in this bird and I won't recover it. (That wasn't the original plan!). I built this to be safe for my family. Everything was done right.
the interior is currently out for annual so the aircraft could be inspected in detail
The aircraft will need a rear fuel pump $800 and the avionics wiring completed. If you are interested I will pay for the IA to finish the work. He recommended new engine fuel hoses at the next annual. I will also pay for a couple months of additional hangaring.
252-382-1884
If someone is interested in the engines, I would sell them firewall forward for $15000 each including props and all sensors for the EDM system. If I can sell both engines I will part the rest of the aircraft.
I would rather see this bird fly.
