  #39
Unread 05-21-15, 10:26 PM
JamesC JamesC is offline
Herb did you ever figure out why your rear engine did not start in flight ? Do you have unfeathering accumulators and if so was the rear one charged to spec ?
I have shut down and feathered the front engine in flight (at 6500 ft) and it re-started no problem. Did not try the rear. Was just reminded of it because am just about to check the pressure in the rear accumulator.
Thanks Herb.
