Thread: Factory Reman
Unread 03-27-15, 07:53 PM
Originally Posted by JamesC View Post
Also getting a Factory Reman (rear eng.) direct from Continental.
Attached pictures of the engine mount (ready to be sent out for NDT) and the rear firewall. I have Gamis but will likely run the factory injectors for break-in/cylinder conditioning x at least 25 hours in case there are any problems.
Looks good James.........are you concerned you will toast one of your GAMI injectors? Guess it's possible, I was going to put mine in the new engine for break in. Not a bad idea though to run the factory units for a couple flights. Just have to take the intakes back off to change em out
