Unread 01-06-15, 06:16 PM
Are the gear doors sagging overnight, partially open? The pump is running because there is a switch that is open. If you have to open the doors then let the pump close them it sounds like it may be a position issue. Any symptoms that could have caused this to start happening? Recent annual inspection or any adjustments made?
