Unread 04-28-14, 09:54 AM
B2C2 B2C2 is offline
Spring loaded gear door panel
The spring on the small panel attached to the forward gear door has broken on my 1969 T337D. It looks like the only way to replace this is to drill out and replace the rivets on both sides of the piano hinge that hold the panel to the door. Has anyone found another solution to this?
