I will check everything you guys suggested. We replaced all of the hydraulic hoses and then hooked up a mule and did many cycles to get all of the air out. We are replacing the micro switch now that controls the doors. I will also slow to under 130 mph before cycling to see if the lower speed helps.
Thanks again everyone.
