Unread 12-09-13, 02:06 PM
Revised again MEB07-1-R05
This revision of the same content, secondary seat stop, has been revised to extend the date of compliance. This is not an AD but a Bulletin that recommends action to be taken for Part 91 ops. All other operations comply as required. Outside the USA typically requires compliance.
If you have already complied with this Bulletin you must update your Supplement section with the attached Continued Airworthiness revision to be in compliance.
