Unread 09-30-02, 05:47 PM
Bob Cook Bob Cook is offline
N69S
Pete.
Are you located permanently or is the AC in transit?
Check with Riley as they are always pulling engines to do the superskyrocket upgrades. Maryanne can help.
You probably want to get rid of the lightweight blocks and go to the CB version which is more robust. Secondly you want to make sure you have the new var cranks in any engine you are going to use for replacement.
If you cannot find low time recent engines then the remans is by far the cheapest way to go.
I assume the engines you have now were made by rolls royce.
fyi bob
