Gear UP
Ernie, had the same problem with my 69 D. I think the squat switch is the first place to check. There is a solenoid under the panel, which prevents the gear lever from going up. If the gear handle will go up, then it's a power pack problem, but I'd check the squat switch first. Also, when you are doing that, check front strut inflation. The gear has to extend enough to have the squate switch make contact with a striker plate. If it is making contact, make sure it has power going to it, and from it.
