Unread 04-25-13, 06:49 AM
JimC's Avatar
JimC JimC is offline
Also interesting to note that the pilot was able to control the aircraft with an asymmetric flap condition...it is probably required from an engineering perspective to be designed that way.
Nope, see above. It doesn't have to be designed that way, but on most GA aircraft it will naturally be that way as part of the average design that makes the ailerons typically not less than 1/2 the flap span. I imagine as you get into more complex systems like the DHC-7 (very large flaps, small ailerons) or the MU-2 (no ailerons at all) that you may get into uncontrollable conditions with an asymmetric flap deployment.
