Unread 05-22-12, 10:29 PM
Electronics International Digital Voltmeter
I am selling a VA-1A-300, digital volt/amp meter with external shunt configuration, serial number 96762. The unit is currently setup for 300 amp systems, however, for $55.00, electronics international will change it to the shunt value for your aircraft. you can also purchse a switch for this unit to select between your front/rear engine so you only need one gauge for your panel. Aircraft Spruce sells this gauge for $369.99. I am asking $200.00 for it.
Description from Aircraft Spruce:
These Digital/Graphic Instruments are solid state and hold their accuracy over time and a range of environmental conditions. The colorful Graphic Analog display emits green, yellow, or red light enabling the pilot to spot problems immediately without interpreting a needle. The Digital display constantly provides an exact indication of each instrument function. Gauges mount in 2-1/4" instrument holes. These instruments (except fuel level) are STCd & TSOd for certificated aircraft.
VA-1A VOLTS/AMPS INTERNAL AND EXTERNAL SHUNTS
The VA-1A is a FAA/PMA approved instrument which features a discharge warning light to act as an early warning device alerting you as soon as discharging begins. This is critical in giving the pilot as much time as possible to reduce electrical load and extend the life of the battery in flight. Also, by monitoring load currents to .1 amps the pilot can check important aircraft functions such as retracts, boost pumps, transmitter power, pilot heat, navigation lights, transponder, strobes, and any other electrical equipment. The VA-1 can replace your existing amp gauge. It is backlit for night operation and operates on 12 or 24 volt systems. Available with internal or external shunt. Wt. 9 Oz.
Name:	Voltage Gauge.JPG
