Unread 05-22-12, 10:21 PM
Electronics International Dual EGT Gauge EE-1P
Used EE-1P dual primary EGT gauge, serial number 21456. Aircraft Spruce sells this gauge new for $599.00. There are no probes with this gauge, however, there are two options. First, the EGT probes on your aircraft may work fine if they are ungrounded type K thermocouples. Second you can purchase new probes from Aircraft Spruce for $87.50/each (need 2). I am asking $250.00 for the gauge itself. It is a primary replacement with high limit alarms which alert when there is a problem. The upper limits are set to 1650, but if you need to have them changed, you can send the gauge back to EI for $55.00 and they will adjust it. They are great to work with.
Description from Aircraft Spruce:
EE-1P: Dual Channel Primary EGT Kit with Over-Temp Lights, 3 1/8" Mount, 2.5" Depth, 28 Oz. Kit, STC'd, TSO'd, PMA'd, 1 Degree Resolution, Accurate within 1/2%, Viewable in direct sunlight, Backlit, Operates from 7.5 to 35 volts at .1 amp.
Name:	Dual EGT Gauge.JPG
