Based on discussions on this forum, I believe the consensus is to go with stainless. I believe that the principal cause of failures is corrosion. In later models, although the IPC still shows both regular and stainless, I think the factory installed stainless and there has been either no failures or far fewer failures than with regular cables. But this is my recollection and I could be wrong. Hopefully others will jump in here and elaborate.
