Unread 04-08-12, 04:16 PM
If you are afraid to run tanks dry, one day it is quite possible that you will NEED to and not be comfortable with the process when you need to be.
It's not a matter of fear. It's a matter of airmanship and common sense. Running a tank dry is stupid.
Running a wetted component dry is foolish. There's no need.
There are a number of reasons to run a TANK dry, but I agree, not the entire engine's fuel. A one hour reserve--ALL IN ONE TANK is the safest option.
An hour reseve in one tank should always be kept anyway. It's still no reason to run any other tank dry.
Run an engine dry in flight, you may or may not get it started again. You may or may not damage the fuel pump and fuel system. You may or may not end up cavitating a pump and either damaging it or being unable to restore fuel flow. You run a tank dry and then attempt to switch tanks, and find yourself stuck on the low tank (I've seen it happen), and now all your fuel is in one place...where you can't use it.
Run a tank low. Don't run it dry.
The only exception I've used in the Skymaster has been using tip tanks; pumped into the main based on time, when needed, but only on exceptionally long flights. I found that based on calculated consumption, I could easily push those flights past 9 hours if needed, without ever being concerned about running a tank dry. Nor would I try.
If you continually plan your flights down to the last dregs and find yourself needing to run a tank dry to make up for poor planning, you're doing yourself no favors, nor are you being kind to the airplane. You're abusing your equipment and your chances.
I presently fly (among other things) a large four engine aircraft internationally; fuel management is an important issue. I can't imagine anyone being foolish enough to push fuel to the limits. Land sooner. Plan tech stops. Get more fuel. Don't go as far. I fly into some remote places and fly some very long legs, and I wouldn't ever, ever consider being foolish enough to compromise fuel, let alone run tanks dry. Whether piston or turbine equipment, it makes no difference.
Teaching others to run tanks dry is irresponsible. Hopefully those reading can understand why, or have enough common sense not to go try it themselves.
