just a thought - i would think that cycles induce wear, base on that theroy low time and
less cycles would produce less wear. with one exception, some a/c had sheet metal screws that were too long and rubbing on the cable. year back i checked that and mine were. just replace the screw with a shorter one. it did not indicate any wear or broken strands; but that
was with 800.0 now it's 2000.0.
one could always drop the flaps well below the 160 maybe at the low end to reduce cable
tension and you really don't need them on takeoff, just a thought.
