  #23
Unread 09-21-11, 01:25 PM
SID's are published
Just received the Maintenance Manual revisions, Part #D2500-2TR9, which update the February 1973 current Maintenance Manual, Part #D2500-2-13.
This is the second revision to the current Maintenance Manual indicated above. The first revision is Part#D2500-2TR8 and deals with the Reel Type Seat Stops, Landing Light Switch and Corrosion Inspection of the Main Landing Gear. This new revision released last October are the Supplemental Inspection Documents (SID) and the Corrosion Prevention and Control Program (CPCP) that have been discussed on this message board for the last 2 1/2 years. See the threads below for more information about SID's:
http://www.337skymaster.com/messages...ead.php?t=2513
This revision, D2500-2TR9, contains 176 double sided pages. This revision covers 1965 -1973 337. The following are the revision numbers for the applicable models.
336 - D238-2TR6
1965-1973 337 D2500-2TR9
1974-1980 337/T337 D2506-8TR9
1973-1980 P337 D2516-9TR8
These revisions were all released 4th Qtr 2010. I ordered mine through Yingling http://www.cessnadirect.com and it was $8.11 online order. These are available in paper only, no electronic format unless you subscribe to a service.
I have not reviewed the document yet as it just arrived by courier. I will start to review today and update soon. If anyone has any questions you are welcome to post here or use private message feature.
