Unread 09-14-11, 10:10 AM
I was asking if the document you referred to is the published SID's that we have been wondering about since the last meeting with Cessna almost 2 years ago. I also ordered a copy of the -13 revision which applies to the 65-73 models. I ordered one through Yingling for $8. I will post the results once it arrives.
Cessna indicated that they would revise the maintenance manual (MM) to include the new inspections (SID's) as the method of print. The fear was if someone hired a big shop that had all the new documents they might feel they are obligated to perform all inspections that the manufacturer has included in the MM.
From what I see the revision was published Oct 2010.
