Unread 05-22-11, 12:03 PM
Turbo RSTOL owner comment
I recently spent a week on the middle for of the Salmon river, and have seen and walked th runways mentioned.
When I was looking for 337's I didn't think the turbo or RSTOL would be necessary, but I ran across one and bought it anyway.
I've had it for 20+ years now, and operate out of a 2665 ft runway at 115 MSL surrounded by trees in a narrow valley www.potomac-airfield.com KVKX.
Washington DC' summers routinely bring the density altitude up to 2,000 in the summer.
TURBOS
The turbo is nice in that you can maintain a high rate of climb ad infinitum. I learned in a non-turbo, and climbing from 9500-11500 was a slow process with four onboard.
Those that regularly fly ice also say turbos are the most valuable option, because ice is usually only a few thousand feet thick, and the turbo's allow you to continue to climb quickly.
The 337 turbos also have variable pressure controllers. That means if you want to loaf at low power the turbos are also loafing. Just power back a bit and you become a non-turbo aircraft.
Another reassuring thing to know is the single engine ceiling of my T337D is 16,800ft. A good friend with a non-turbo 310 just got posted to Colorado, wher eit suddenly hit him his single-engine service ceiling is 500 BELOW field elevation.
STOL
I've got the RSTOL, which is amazing.
As a former helicopter owner/pilot, the whole fixed wing concept of having less and less aerodynamic control just as you approach the ground was intuitively insane.
The RSTOL brings the envelope of control down to much lower speeds. In other words, a you still have a LOT of control at closer to normal speeds.
The RSTOL stall speed landing configuration is down around 50 knots (or less). I routinely touch down at 65-70. The primary benefit is not that you operate at the edge, but it goves LOTS of control at very slow speeds, instead of just 'enough.'
I also routinely go into Hatteras, noted for occasionally wild winds. My record so far was landing in a 28 knot gusting crosswind at IFR minimums. The STOL gave me lots of aileron control, and the two huge rudders cant be beat for any crosswind.
The RSTOL also has vortex generators behind the rear engine. Their benefit is single engine climb of 450 fpm with either engine at gross.
Just some things to consider.
D
